Motorcycle.com
Old 07-17-2002   #1 (permalink)
Well after I broke one rear turn signal off the bike I figured now would be the time to shorten the stems. It took awhile but I finally freed up the stem form the light. I have a call in to a friend to have the stems machined down. I am also interested in converting them into run-turn-brake lights. I found a module at Ma's Cycles that should work, but I need to replace the lens. So does anyone knoe where I can get red lens to install on the turn signals. I am trying to avoid buying a whole new assembly.
Thanks,
Tinman
Old 07-17-2002   #2 (permalink)
Favorite Bike: 98 Thunderbird
Why not save yourself a lot of trouble and go with some aftermarket lights. The bullet lights would look good on a Triumph, and they come in a double filament version so they could be used for turn & running lights.
You can also get red lenses for them.
Turn signals don't! Anchorbend Twins Technical Talk 9 05-02-2007 09:29 AM
turn signals hardboild Triumph SuperSports 1 09-26-2006 07:43 AM
Turn signals! RocketRay The Rocket Science Forum 2 07-24-2006 07:44 PM
turn signals HardCharger Daytona Deliberations 9 02-07-2005 12:01 PM
Turn signals Trophy 2 08-09-2004 02:02 PM
