Old 09-14-2003   #1 (permalink)
I have a 96 Daytona 1200. The entire time I've had it, in order to adjust the chain I've had to loosen the pinch bolts AND the axle. The Axle pinches the eccentrtics together so that when it is tight, the eccentrics won't turn, even if the pinch bolts are loose.
I just noticed (yes I know, I'm a dumgbass) that the manual says to adjust the chain, all I should need to do is loosen the pinchbolts. Is this true?
If so, it seems like I'm either missing a spacer, or I'm not putting the wheel and spacers together properly. Anyone who could help with this, I'd sure appreciate it.
What I really need is an exploded diagram of the rear wheel/cush drive/axle assembly so I can compare it to my bike...anyone?
This is sorta an emergency, because I'm supposed to ride about 1100 miles over the course of next weekend, and I;d rather not kill myself due to improper rear wheel assembly.
Thanks!
dietDrThunder is offline   Reply With Quote
Old 09-14-2003   #2 (permalink)
Thanks!
Old 09-14-2003   #3 (permalink)
Thanks!
Old 09-14-2003   #4 (permalink)
Thanks!
Old 09-15-2003   #5 (permalink)
Favorite Bike: Daytona Super III
Hinckley's Avatar
Other Motorcycle: Suzuki GT750
Extra Motorcycle: CB900F FOR SALE!
Something is definately not right there. you shouldn't have to loosen the Axle to adjust your chain. The Adjusters and the axle should move as one unit in an effort to allow you to adjust the tension of the chain without having to adjust the alignment as well.
I have an exploded view of the swingarm but it is in a tif file. If you or someone else can tell me how to convert it to a file that can be uploaded here, I will send it.
UFOB #56
Hinckley is online now   Reply With Quote
Old 09-15-2003   #6 (permalink)
Hinckley's Avatar
UFOB #56
Old 09-15-2003   #7 (permalink)
Hinckley's Avatar
UFOB #56
Old 09-15-2003   #8 (permalink)
Hinckley's Avatar
UFOB #56
Old 09-15-2003   #9 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
hey hinckley, if you send it to me I will convert it and post it onto the site.
Mick...
Old 09-15-2003   #10 (permalink)
Mick...
Question about axle nut covers for rear wheel jvo Sprint Forum 4 05-03-2007 04:27 PM
Rear wheel question quagmire Classic, Vintage & Veteran 2 03-25-2007 07:45 PM
easy rear wheel question internetay Classic, Vintage & Veteran 2 05-26-2006 08:42 AM
Pulled the rear wheel off. Got a question. 00wabbit Hinckley Classic Triples 4 03-19-2005 04:33 AM
Chain/Wheel question Chumpmaster2k1 Hinckley Classic Triples 3 08-17-2004 08:17 AM
