After years of fun My T309 has gone (a rod badly disconnected from engineshaft)
I bought a TBS engine with his carbs and putted on my Adventurer.
Sprint Cams I had on prev engine were traslated to new by my mechanics.
It was necessary to reverse rearset leverage to get 1st down.
I arranged some rubbers (fork types) to keep the same airbox (it was drilled when I putted on cams, Mikunis had 110 MJ) and I rejetted little less richer (STOCK 98 MJ)obtaining a good erogation.
When on the road I feel the gears keeping very very long. Anyway the bike comes without problems to 170 KMH, (about 100 MPH) at 7500-8000 RPM in 4th speed, (with two left to put in) then stalls...
I was wondering about putting on a 48 teeth rear sprocket to shorten gears run. Is there so much final diameters difference between 17"x60mm TBS and 16"x80mm ADV wheels to justify that gear gap or I lost some power?
What is the best I can do next to solve my doubts? (es. dynoruns, sprocket swapping, TBS airbox...)
