Old 08-12-2003   #21 (permalink)
GaryD's Avatar
Yep, the airbox drain should be plugged. By the way, everyone should check this drain line out frequently to see if you are getting fluids of any type in it. I guarantee you'll never get any antifreeze in your Bonnie's airbox drain.
Unsafe at any speed. First Terranaut.
GaryD is offline   Reply With Quote
Old 08-12-2003   #22 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Ahhh. That is the plug I lost. Now for the task of figuring out which hose is the airbox drain! That might explain the jerkey throttle response.
Will
SponsorHouse profile
Old 08-12-2003   #23 (permalink)
Will's Avatar
Will
Old 08-12-2003   #24 (permalink)
Will's Avatar
Will
Old 08-13-2003   #25 (permalink)
Common Sense dictates hose should be plugged; could find no reference in shop manual. My earlier Hondas with airbox drainlines had much smaller (Diameter) hoses with no plugs but were tapped in front of the filter as I remember. And I was by the dealer yesterday. New Daytona 600 looks great!
[ This message was edited by: RoadHazard on 2003-08-13 02:46 ]
Old 08-13-2003   #26 (permalink)
Old 08-13-2003   #27 (permalink)
Old 08-13-2003   #28 (permalink)
GaryD's Avatar
I doubt the jerky throttle response is due to the airbox drain plug being out, unless you have sucked some foreign matter into the carbs through it.
Old 08-13-2003   #29 (permalink)
GaryD's Avatar
Old 08-13-2003   #30 (permalink)
GaryD's Avatar
Which Gasket sealer, there are so many Ahobie17 Classic, Vintage & Veteran 10 11-06-2007 10:44 PM
tank sealer Mecchanica Classic, Vintage & Veteran 2 10-02-2007 09:38 PM
Head gasket sealer flyrodder Classic, Vintage & Veteran 6 09-21-2006 11:51 AM
cover sealer okiecityflash Classic, Vintage & Veteran 9 04-10-2006 05:13 PM
Kreem Tank Sealer dowop Twins Talk 24 08-03-2005 01:37 PM
