On 2007-02-05 17:41, tealetm wrote:
So how much were the new carb parts from triumph?
And honestly did you notice a difference? I had mine apart when I first got the bike, but haven't touched them in 12k miles
tealetm,
Around $200 for the carb parts (after my RAT discount) and another $25 for the rubber carb boots but that's for a 4 cylinder engine. Your triple would be cheaper. I went ahead and replaced all four sets of floats and the float needles. Some would say why replace the floats when only the needles were need. But other sources I trust would say floats don't always "float" the way they used to when you have as many years and miles as I had on my bike. Not to mention the floats being covered with thick rust.
Age, wear, cracked carb boots, and rust from the tank in the carbs had all conspired to cause my bike's performance to slowly deteriorate over time. Because of all these issues the result of the rebuild was, in my case, a significant improvement. After installing all the new gaskets, o-rings, and float assemblies along with new carb boots the bike now runs like new!
I'd say if your bike has 50,000 miles or is more than 10 years old you should at least check the float needles and carb boots for wear and cracks. I know my bike runs a LOT better now. For example, because the float needle seats were not sealing, causing too rich a fuel mixture thus causing the plugs to foul. I was only getting 29-33 mpg at best. The bike would also bog down at around 7500 rpm so I knew I had problems, I just didn't know how bad till I took everything apart. But now after the rebuild, cruising along at 70 I can pull back slightly on the throttle and roar past 100 in the time it takes to read this. So yes, In my case it made a huge difference!
dc
[ This message was edited by: daytonacharlie on 2007-02-16 16:55 ]
