You need a body hammer, and either a stud gun or heavy duty epoxy. The epoxy is the heat free way, throw epoxy on it and attach a rod or plank of sorts then try to pull that mofro out. The Studgun, you put studs, pull, more studs, pull, ect ect. Starting from the outside in of course.
OR!!! You can cut the bottom out, hamer and dolly it from the inside, then reweld.
