BikeBandit
Old 01-16-2007   #1 (permalink)
heres the thing. i have a ARD mag. so i got the tympanium voltage regulator. all I'm running off the regulator is the head light,horn and brake lights. i have the bike wired up with no ignition just a toggle switch. i was wondering if i have to run it positive ground still. is the power coming from the alternator positive ground?(if that makes any sense) the instruction say the the regulator can be run either way. it doesn't matter to me. but was just wondering?
support www.choppertown.net
dgfironworks is offline   Reply With Quote
Old 01-17-2007   #2 (permalink)
Why would you want to go positive ground ? In the old days these things were not standardized. UK stuff was positive ground. In the US, it depended on who made it whether it was positive or negative ground. That all went away in the US when we changed to 12v. in the mid 1950's. I think in the UK it lasted a little longer. Now we can swap parts through out the world with no problems because we standardized everything to 12v negative ground.
[ This message was edited by: Lone-Rider on 2007-01-17 16:19 ]
Lone-Rider is offline   Reply With Quote
Old 01-17-2007   #3 (permalink)
Favorite Bike: 1978 Triumph Tiger 750
hobbit's Avatar
Other Motorcycle: XLH883C Sportster
Extra Motorcycle: 1978 CB750 Hardtail Chop
Try this . . . http://www.britcycle.com/Manuals/331NegGrdInst.pdf
Amazing things indicators . . . pity yours don't work.
http://www.aavmcc.com
http://www.putfile.com/hobbitaavmcc
hobbit is online now   Reply With Quote
Old 01-18-2007   #4 (permalink)
thanks guys. good help!
Positive ground decal location Ahobie17 Classic, Vintage & Veteran 6 10-18-2007 02:38 PM
positive ground trouble mhall008 Twins Technical Talk 1 04-01-2007 07:23 PM
Do i have to run my bike positive ground? dgfironworks Classic, Vintage & Veteran 8 01-27-2007 03:31 PM
How rough is a dyno run on a bike? ohiorider Twins Talk 6 02-06-2006 07:42 AM
S4: Positive or negative ground? Will Modifications & Workshop Talk 11 12-19-2003 12:44 PM
