Hi everyone. I have posted on the Rocket forum about a starting problem I have with my Rocket. I thought I'd post here hoping more people would see and maybe offer advice.
The problem started a couple of months ago. The bike runs fine. Then refuses to start in the morning. The symptoms present themselves as a battery fault. The bike turns over really slowly and refuses to start unless jump leads are used.
I have cleaned and tightened all battery connections/earth straps etc. I have removed the starter motor and had it bench tested that is okay.
The battery has been load tested by the dealer and has been used to start another Rocket so the battery is okay.
Now when I have put everything back together again the headlight fuse has blown which I believe is wired into the starter suystem?
What else can I check before facing open wallet surgery at the dealers. The bike is out of warranty.
Thanks :hammer:
The duck came off worse!!!
