Old 12-12-2006   #1 (permalink)
I am wondering if JB weld will work to fix this problem. The steering stop on the frame is not broken off, but it is dented in which allows my handlebars to touch my gas tank. I do not want to scratch the tank at all because I just got it painted. If JB weld will not work then what should I use? This problem is only on the right side of the frame.
rider955i is offline   Reply With Quote
Old 12-12-2006   #2 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
Sure - don't see why not.
You might try making a little 'mold' for it in place out of masking tape; then file to final shape & a little dab of sliver paint.
Should be plenty strong (for normal parking manoeuvres) if you get a good bond - clear the paint of the bonding area first.
GSXR 1000 Front End Swap
Old 12-12-2006   #3 (permalink)
Thanks DEcosse I was going to do it exactly how you stated just didn't know if it would flake off, chip, or anything else.
[ This message was edited by: rider955i on 2006-12-12 22:12 ]
Engine stall-out/Shut-off at stop light/stop sign??? jrelloway Daytona Deliberations 7 02-01-2008 02:16 PM
Need handlebar ends for Pro-Taper handlebar Aurelius Speed Triple Forum 2 10-20-2007 11:38 PM
frame blanks for frame / swing arm on 1050 ST PeirreOBollox Sprint Forum 0 03-11-2007 08:41 AM
Thruxton frame vs. Bonnie Frame HiVel Club Cafe 5 09-20-2006 08:16 PM
Best Handlebar Risers? And warning on frame sliders Sprint Forum 16 02-18-2005 05:41 PM
