BikeBandit
Old 12-11-2006   #1 (permalink)
I just found a set of S3 front brake calipers with steel braided lines. I'm trying to pull them apart to fiddle with them, clean up etc, but need to take the lines off, but I'm buggered if I can figure out the size of the head of the banjo bolt! 14mm just a smidgen too small, 15mm way too big. ***?! Is there a special banjo bolt wrench?
Help.
My next question is likely to be - how do I get the pistons out? - but I'll save that one for tomorrow.
Thanks
Cheers
Barry
BarryG is offline   Reply With Quote
Old 12-12-2006   #2 (permalink)
Favorite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
I believe it is a 9/16 wrench or socket for that matter.
you can push the pistons out with compressed air, or just pull them out of the bores with a non marring pair of pliers (don't scratch the pistons!!)
I have enough money to last me the rest of my life, unless I buy something.
chefjpd is offline   Reply With Quote
Old 12-12-2006   #3 (permalink)
Use about 10 to 20 lbs of air to blow them out...more, if required. Put a folded rag inside the caliper to keep them from popping out and dinging the caliper or the piston. Apply the air in little bursts.
Mecchanica is offline   Reply With Quote
Old 12-12-2006   #4 (permalink)
Thanks, guys.
Managed to get one off (r/h), the other is stuck fast. Also stuck is the pin that goes through the caliper that holds the spring thing. I think they'll need power tools to get them out! I need to take them to the dealer anyway, have them pop out the pistons, compressed air being in short supply in the Barry household. I suspect the bike these came off sat for a while unused (crashed?), but it's odd the r/h side came apart fine, the other is well stuck.
Cheers
Barry
Old 12-13-2006   #5 (permalink)
chefjpd's Avatar
barry, try a soak in WD40 or the like, that should free up the pin and caliper.
use anti-sieze upon re-assembly
Old 12-13-2006   #6 (permalink)
WD, a little heat, and tapping with a soft mallet to break up the corrosion. And some patience.
Old 12-17-2006   #7 (permalink)
Patience??? That's in about the same amount of availability as compressed air around me - hah!
Thnaks for the advice, I'll give it a go.
Cheers
Barry
Bolt Size? NewOldSkool Twins Technical Talk 2 10-18-2007 03:50 PM
bolt size RT Twins Technical Talk 2 08-01-2006 08:42 PM
Fuel line size? Beemie Hinckley Classic Triples 8 05-06-2005 08:48 AM
fuel line size cat Classic, Vintage & Veteran 3 04-26-2004 04:58 PM
What size bolt is this? T3 Sport / Touring Forum 19 09-14-2003 04:15 PM
