Steevg:
Most chains are "O" ring sealed, if you look closely you will see the "O" ring between the side plates. You should be able to clean it with kerosene and not hurt anything. There are also some products made for cleaning chains, take a look on the web or go to your local cycle shop.
I clean my bike (chain and all) with S100 cycle cleaner which works pretty good, then lube chain with PJ1 chain lube.
Scott
96 Sprint (BRG) - Busa 6 pot calipers,
ZRX 1100/1200 fork caps, Racetech GVEs, Nissin Remote Res. master brake and clutch, Storz Perf. handle bar kit/w super bike bars.Replaced Mikunis with Keihins.
