BikeBandit
Old 07-15-2003   #21 (permalink)
GaryD's Avatar
I have a Fiamm Freeway Blaster (134db) on my T100. Horn comes with a brassy looking galvanized finish that is grainy and probably doesn't match anyone's bike. I used steel wool to smooth and score the finish, then painted the front disc chrome and the remainder black, including the mounting brace and bolt. As I recall there were about 5 four inch long mounting braces and one 90 degree brace. As the Fiamm horn is about and inch deeper than the stock horn, I took one of the four inch braces, put it in a vice and bent it at a 45 degree angle about an inch from the end, then turned it over and bent the other end so that both ends were on parallel planes. Looks great & works great.
Unsafe at any speed. First Terranaut.
GaryD is offline   Reply With Quote
Old 07-25-2003   #22 (permalink)
I got the the Freeway Blaster Part#72112 and hooked it up. NO BEEP just a clicking noise. Do I need a relay or did I get a defective horn?
Old 07-25-2003   #23 (permalink)
Old 07-25-2003   #24 (permalink)
Old 07-25-2003   #25 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Bang it on the bench Tom! Seriously, it free off resonating horns if they stick.
Mick...
Old 07-25-2003   #26 (permalink)
Mick...
Old 07-25-2003   #27 (permalink)
Mick...
Old 07-25-2003   #28 (permalink)
Thanks Mick...I slamed the s%$#@t out of it and now it works. I love things you can slam to make work.
Tom
[ This message was edited by: LegendTTom on 2003-07-25 21:43 ]
Old 07-25-2003   #29 (permalink)
Tom
Old 07-25-2003   #30 (permalink)
Tom
warning light replacements tacomaguy Hinckley Classic Triples 10 06-01-2007 05:45 PM
mirror replacements gooseeggtona955 Daytona Deliberations 9 06-10-2006 09:54 PM
please i need directions to replacements carlosjedi Hinckley Classic Triples 5 05-19-2006 01:05 PM
Pea shooter replacements ToddZimardo Hinckley Classic Triples 3 05-14-2006 09:55 AM
Brake replacements rkx Sprint Forum 2 07-13-2005 10:48 PM
