Old 08-03-2004   #1 (permalink)
This is a follow on from "jm's" post of the same title on the Trophy site - just opening up to a wider audience.
My 95 Sprint 900 has just started doing pretty much the same thing in the same rev range.
I have 'tested' some scenarios and have found:
- when cruising and I pull in the clutch, the revs will hang at 2800
- when slowing to a stop, if I leave the clutch engaged just long enough to get the revs down below 2500, then I get a correct idle.
- it seems to be heat related since it only happens when the engine is godd and hot - and when the air temp is above about 85.
Could the heat be leaning out the mixture - or could there be a problem with an idle circuit?
Racing Green (what other colour should a Brit Bike be)?
RacingGreen is offline   Reply With Quote
Old 08-04-2004   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
This is only a guess, and it is based on SU carbs, so take it for what it's worth. You could have either a sticking float or something that heats up and starts to rub in either the carb or throttle linkage somewhere. I would start by looking for things that are rubbing, just because it is easier, but my guess is that you will find something gummed up inside the carbs.
Will
SponsorHouse profile
Old 08-05-2004   #3 (permalink)
Favorite Bike: Vincent Black Shadow
dhall10's Avatar
Other Motorcycle: Yamaha Star Roadliner
Just had something similar on my Adventurer. It turns out I had incorrectly adjusted the throttle cable when I installed the new one, no slack in the cable(?) they said.
Dave Hall
My Photo Album
Bubbleheads and Bikes Forum
dhall10 is offline   Reply With Quote
Old 08-07-2004   #4 (permalink)
GaryD's Avatar
Common problem with trash in the carbs is running to lean which can cause a slow descent from high revs when the throttle is closed. Cleaning float bowls may be all you need.
Suggest you fix ASAP.
Unsafe at any speed. First Terranaut.
GaryD is offline   Reply With Quote
Old 08-09-2004   #5 (permalink)
I'll cautiously declare this 'fixed' now.....
Tweaking the throttle slack made no difference, so next I looked at the idle adjustment knob and lowered the idle speed back about 100rpm (probably to where it should have been). Rode 150 miles the next day with no problems. Every time I shut the throttle the revs dropped nicely - no issues at all.
Although the previous setting was no problem when the engine was cold, I suspect heat caused something like this to happen:
Since in the throttle-off position the butterfly would not be quite closed, and when the engine is hot the mixture is leaner......when shutting the throttle, enough lean mixture was being sucked from the main jet to over-ride the idle circuit......or whatever.
At least it works - and thanks to all for pointers.
Idle RPM too high OwenS Speed Triple Forum 3 10-16-2007 07:40 AM
High RPM surging... Yak Triumph SuperSports 4 09-28-2007 10:10 PM
RPM stays high when getting off throttle jm Trophy 14 08-27-2006 09:31 AM
High beam indicator stays on after start up jdub3 Speed Triple Forum 10 06-12-2006 09:11 PM
High RPM at idle upsidedown_04 Sprint Forum 5 09-29-2005 12:02 PM
