Old 11-27-2006   #1 (permalink)
ColinHitchcock
Please help an idiot, I need to fit a centre stand spring; brute strength and ignorance has not worked. Does anyone know if some kind of spring extender gizmo exists? Thanks in anticipation. colin :???:
Old 11-28-2006   #2 (permalink)
hook a loop of strong string to it and pull. don't get your hands in the way.
darcy
-Darcy-
BIR #174
"My eyes.....the goggles do nothing!"
Rainier Wolfcastle
DickBender is offline   Reply With Quote
Old 11-28-2006   #3 (permalink)
Favorite Bike: 2002 Triumph Thunderbird
TonyD's Avatar
I used a nail/tack puller - the kind that looks like a screwdriver, but with a 'V' shaped tip. With the stand in the raised position, spring attached, I used it to push each strand of the hook at the other end of the spring over the retainer on the bracket. For extra pressure, I extended the length of the tool handle with a piece of old aluminium tubing I found.
Tony
My Photos
TonyD is offline   Reply With Quote
Old 11-29-2006   #4 (permalink)
Favorite Bike: '74 850 Commando
Other Motorcycle: '79 T140E, '96 Trident
Hold one end of the spring in a vice. Bend the spring and insert suitable sized washers where there is a gap between coils, bend the spring in the opposite direction and insert more washers in the gaps. Install the spring on the bike, pull the washers out.
daveforty is offline   Reply With Quote
Old 11-29-2006   #5 (permalink)
ColinHitchcock
Very many thanks all. Looped a strong cable tie on one end and inserted a long handle in loop as a lever-result.
colin
Old 11-29-2006   #6 (permalink)
TonyD's Avatar
Nice one, Colin. I'll try that myself next time I encounter the problem.
Tony
My Photos
Old 11-29-2006   #7 (permalink)
Motion pro makes a nifty t-handled device for fitting springs on exhaust pipes. Sort of a mini meat hook.
Life's too short to ride Jap bikes!
bigern2300 is offline   Reply With Quote
You know that spring is here... bigred900 Hinckley Classic Triples 1 05-01-2007 02:46 PM
Is it Spring yet Buzzard The Rocket Science Forum 3 03-20-2007 06:26 AM
Spring is here.... BWW RAT - United Kingdom 1 03-11-2007 04:11 PM
It could be Spring! GeneralPig RAT - United Kingdom 14 05-26-2006 12:37 PM
side mirrors...extend? Stroke Tiger Chat 8 07-12-2005 12:35 PM
