On 2003-07-08 07:46, jerrysussman wrote:
Hi. I ride my 2000 Legend in Metro D.C. Heat and humidity wise, it'll probably give North Carolina a run for the money.
*snip*
I assume that you're not riding in shorts (if you are, normal heat may seem worse than it really is). If coolant is not circulating/fan isn't coming on regularly, might want to have dealer check out thermostat and engine coolant temperature sensor....Jerry
Jerry, my dealer says of the heat on my ST that there isn't a thermostat on the newer Triumphs - that the green goo is always flowing through. As for the ST and heat, there is ALOT comming out the bottom of the fairing...
I usually turn my right wrist and up shift if its bugging me :-D
Otherwise I expect the ST will be keeping me toasty for an extended riding season!
coldnight
with hot feet
