Old 07-31-2004   #1 (permalink)
Hey guys - I made a serious poo poo error the other day while removing my tank form my 595. I broke off the intake fuel fitting and then to add more to the fire, I hashed the threads trying to remove what was left. My Questionsis iis it possible to just "re-tap" the fuel plate and install a new fitting without having any serious leaks...??? I hate fires!
Old 08-01-2004   #2 (permalink)
Favorite Bike: Triumph
tigertales's Avatar
On my Tiger with 2200 mi I had fuel leaking on a hot day (Have a thread under 'Fuel...do it stink' in the Tiger section)
Some time back I had received a set of metal fittings from GREAT BAY Triumph so thought I could just switch out the fittings.
After removal of the quick release, the lightest turn of the fitting in the tank snapped it off with about a 1/16 standing proud of the threads.
It seemed soft enough so I tried to 'unscrew' the broken threaded portion only to end up with a rough plastic collar in the threads that seemed to work harden and get stuck even harder.
On the second fitting I was more careful, lightly twisting back and forth detecting the movement only to have it snap off clean.
Here is my solution - if the fitting snaps off, before trying to hog it out of the hole - heat up a screwdriver large enough that when hot pressed into the broken part will leave two slots. Hold the screwdriver in place until cool and slowly unscrew the fitting. Mine came out pretty easy.
On the hole with the messed up plastic bits wedged in the threads, I put a dab of grease at the back of the hole (to catch particles) used a dremel tool with a wire brush and 'combed' out the threads, Then I restored them with a pipe tap. (1/4 x 18 NPT)
After, I used a pipe cleaner I had wrapped abound a wire (shirt hanger size) coated lightly with grease and cleaned out the fuel hole with my 'drill'.
All done with the tank in place, New fittings installed, the key cycled a few times to prime the fuel pump and I was rewarded with a running bike ...no more leaks!
Hope this helps.
tigertales is offline   Reply With Quote
Old 08-01-2004   #3 (permalink)
Thanks so much for the info. I'm going to give it a go and see what happens. I'm always a little nervous when dealing with fule and hot machinery. Especially my Screamn' T
Thanks again
Old 08-25-2004   #4 (permalink)
Well it worked, I bought a small tap and die set. Re-threaded the fule plate screwed int he fitting and so far, three days later she is still holding.
THANKS AGAIN !!
Fuel Regulator Recall??? - Starting issue?? 955iLimited Daytona Deliberations 21 07-13-2007 09:21 PM
Potential Fuel Tank Issue? desmoface Speed Triple Forum 19 04-20-2006 09:25 AM
PLEASE HELP finding a 05S3 fuel pump plate aaronb_dsn Speed Triple Forum 0 03-06-2006 11:33 AM
Fuel Plate Problems Daytona Deliberations 0 07-31-2004 08:42 PM
Regarding the fuel connection issue: Scottius Sprint Forum 7 03-24-2004 06:37 AM
