Old 07-31-2004   #1 (permalink)
Trying to install a Throttlemeister on my '96 Trident 900 and the right-side Allen bolt on the original bar end weight is stuck and now stripped from my attempts to break it loose. I've tried drilling with a 6 mm tap and die bit. Maybe 6 mm is a little too large because I only manage to further destroy the capacity to use an Allen wrench on the bolt.
I've removed this bolt before, it must have some rust in it and I must have overtightened the last time I replaced the handlebar grips (earlier this spring).
I'd be most grateful for any recommendations about how to get this bolt loose...
Many Thanks,
Old 08-01-2004   #2 (permalink)
Your local hardware or auto-parts store probably carries a selection of different size screw/bolt extractors. They're inexpensive and easy to use.
j98
j98sprint is offline   Reply With Quote
Old 08-02-2004   #3 (permalink)
GaryD's Avatar
A little penetrating oil and an impact driver (when you hit the end, it turns) will loosen almost anything that isn't rusted beyond salvage. The impact lossens the threads. However, it sound to me as if you have one chance with a drill and a screw extractor before you have to almost completely drill it out.
I suggest you buy a full set of extractors as - if the first attempt doesn't work, once you get the head of the bolt/screw off and start drilling the shaft, you usually can get good oil penetration and a small extractor should then work on the shaft of the bolt alone.
Unsafe at any speed. First Terranaut.
GaryD is offline   Reply With Quote
Old 08-02-2004   #4 (permalink)
Favorite Bike: 2002 Sprint ST
Kroil is the best penetrating oil I've ever seen. Soak it and let it sit for a day or so and it should come out very easily,
nose fairing removal advice jackella Speed Triple Forum 2 04-14-2007 11:11 PM
AI removal kit bolt sizes Healey_100 Club Cafe 4 10-17-2006 12:52 AM
Help... Fairing Removal, Lost Bolt lloydo123 Sprint Forum 2 05-15-2006 07:35 PM
Help, Please. Tank removal (plus other serious advice) ElTigre1 Sprint Forum 15 03-01-2006 03:43 PM
Front Axle Bolt Removal Please Help Kngelv Sprint Forum 3 03-29-2005 06:53 PM
