Old 07-03-2003   #1 (permalink)
Favorite Bike: Depends on mood
Ballacraine's Avatar
Other Motorcycle: Both Brit & Italian
Don't suppose anyone has done this, but I gotta ask.
I am wanting to get some balanced downpipes to fit my Legend but I want to retain the centrestand. I have a feeling the early T3 downpipes may be suitable or some off the early Speed Triples, which should look a bit smarter?
Retention of the centrestand is non-negotiable! :-D
Anyone in the know?
TIA
Nige
In faecorum semper solum profundum variat.
(Always in the s**t it is only the depth that varies)
Nige's Gallery
Ballacraine is offline   Reply With Quote
Old 07-03-2003   #2 (permalink)
Anyone in the know?
TIA
Nige
Nige's Gallery
Old 07-03-2003   #3 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
I've been thinking the same thing Nige, but all I keep coming back to is that it would be easiest to modify the existing pipes, that way you could put the balance pipe wherever you wanted it. All the other pipes seem like they would need surgery of some form to fit as there doesnt seem to be any standard position for the rear mountings or standard geometry to the mufflers.
Mick...
Old 07-03-2003   #4 (permalink)
Mick...
Old 07-03-2003   #5 (permalink)
It is not so much the geometry of the rear mount that is my problem, Mick. (I would be re-using the Rayguns anyway).
The area of my concern is the horizontal run & fouling the centrestand. The early T3 variants seem to have a balance pipe running under around this point & from what I have seen this would be a non starter for the Legend. The balance pipe / central split has to be in the downward run of the pipe to be certain of being viable.
I have toyed with the idea of custom build on the existing downpipes, but I would view this as a last resort. I really want to retain the standard parts if I can.
Any further input would be most welcome.
TIA
Nige
Nige's Gallery
Old 07-03-2003   #6 (permalink)
TIA
Nige
Nige's Gallery
Old 07-03-2003   #7 (permalink)
From what I know nige the balance pipe on the 2000 on TBS does not itself interfere with the centerstand, it's the shape of the exhaust headers that does it. The up sweep is further back so what happens is that the arm of the centerstand hits it. I am pretty sure that it's a common misconception that you cant fit the centerstand because of the balance pipe. But some people have actually fitted centerstands to the 200 model year tbs without removing the balance pipe at all. they have had to cut the arm off the side of the stand though. I am assumign thats because it hits the upsweep on the TBS pipe.
I know what you mean about not wanting to modify your standard parts. I was just thinkign that a set of Legend headers would be as easy to obtain second hand as those from any other T3. If you were then positioning the balance pipe yourself you shoudl be able to do it in a place that would ensure the centerstand wouldn't hit it.
Mick...
Old 07-03-2003   #8 (permalink)
Mick...
Old 07-03-2003   #9 (permalink)
The variants that have balance pipes do seem to have a lot more clearance between the back of the sump & the centrestand lugs than there is on the Legend.
You may be right that the best option is a custom build with the balance pipe grafted in somewhere under the radiator.
I was hoping that I would be able to find out which, if any, of the first generation speed triple downpipes would be a pretty straight-forward fit.
Nige. :???:
Nige's Gallery
Old 07-03-2003   #10 (permalink)
Nige. :???:
Nige's Gallery
EFI Downpipes marmite Twins Technical Talk 13 11-25-2007 11:56 AM
balanced wheels vs headstock bearing vs bad california roads yakoo11 Triumph SuperSports 2 07-20-2007 09:47 PM
I mounted and balanced my tires. Found rust. [pics] Bryan Twins Talk 12 09-24-2006 11:21 AM
Balanced or unbalanced exhaust pipes? kiwee Classic, Vintage & Veteran 8 08-18-2006 07:27 AM
carbs not balanced Modifications & Workshop Talk 3 04-04-2005 09:55 AM
