Mine has 21k on it and still good. When chains are worn out they get a redish dust-like film on them, need adjusting every few hundred miles and at low speeds the bike will be real jerky from the tight spots.
Triumph recomends putting a weight in the middle of the chain to measure stretch but an eaiser way is to try'n pull the chain straight back off the rear sprocket. Any significant amount means the pins are wearing down, but you'll be able to tell by adjustment intervals more than anything.
For you, I would soak the chain down in a good penetrating oil like WD40, CRC or YIELD, let it sit for a while then ride the bike to fling it all off. After you're done spray it with a good chain lube like ProHonda or something and you're good to go. :-D
[ This message was edited by: stevent on 2004-07-27 08:56 ]
stevent....."May the Goddess turn the hearts of those who hate us, if not their hearts then turn their ankles so we'll know them by their limping..."
