A middle of the road quality brand is Craftsman (note: the cheap line used to be called Sears, now is called Companion -- not guranteed). Other brands are good as well, such as Armstrong, Blackhawk, etc. Though Taiwanese made, the Wally world Stanley's can occasionally be bought for a good price.
If you subscribe to the Sears web site, you will get the ads sent to you. Though I have (and occasionally still do) buy cheap tools, they are either when the wallet is thin, or they will be modified anyhow.
Sears will have 100-300 piece starter sets on sale regularly. They are a great way to start out. If you buy a tool box, buy one quality higher than you think you can afford (trust me). It will be around you for a long time. Lowes Depot sell decent looking boxes as well. sears are made by Waterloo. A top box is a good starter, but a bottom box will give you a table top to work on (or at least to set things on). Ammo boxes are very good for starters too. A scribe is a good cheap tool too (used to mark things).
Standard & deep sockets, long handled needle nose pliers, hardened tip phillips screwdrivers (you can always start with a bit driver & set, they are usually hardened; Ace and Sears sell one with a rubber block that slides over the driver handle that is pretty complete, including some Torx). A three piece set of allen (hex) in sae & metric, and torx. If you buy an L wrench set(s) buy the ball end type (Bondhus is another good brand in this).
If you are using a crescent wrench, you will eventually end up using a vise grips locking wrench (the vise grip brand is the standard) due to rounding the bolt head! Occasionally you will need to use vise grips, but that's another story.
A (harder to find) 1/4" drive torque wrench & and a 1/2" torque wrench (cheap) in the beam style are hard to beat, as they will hold torque settings better than most medium to lower price click wrenches.
2 sets of combination wrenches. Usually don't include 16 & 18 mm due to sae (fractional) wrenches being plentiful. And this size isn't commonly used anyhow -- oh, we have Triumph's!
A hammer type impact wrench. From Harbor Freight (cheap) to Snap On ($$). Cheap seems to usually be ok here. Motorcycles and corrosion to case bolts (and master cyclinder covers) will want you wonderinghow to remove the ruined screwhead. Use one of these first.
A can of gasket maker. A can of anti-seize. A book from Seqouia press:
http://www.amazon.com/gp/product/188...lance&n=283155. Ace also sells it.
Don't forget the local swap meets and yard sales, as well as craigslist. Latex or the blue gloves harbor Freight sells (not latex, can't remember the material, Home Depot sells them as well -- Stanley makes the Husky tools, decent brand).
[ This message was edited by: Mojoinco on 2006-10-17 16:18 ]
