Have had to adjust the chain on my 2000 Sprint St again (last time 1000 mi ago). There are definite tight and loose sections when I turn the rear wheel, I don't know if the chain is wearing or if the sprockets are ovalling. The teeth don't look bad but I have no experience judging sprocket wear. I only found one or two tight links in the chain, but I did notice that some of the link rollers spin freely when I am cleaning the chain
The bike had 10K when I bought it and about 14,200 now. I am considering replacing both sprockets and the chain just to remove all doubt about the condition.
I see several recommendations in forums against the OEM parts but I also see recommendations for the Triumph front sprocket. Apparently the Triumph part has rubber vibration isolators built into it.
Any one have suggestions for brand/model of chain and sprockets for the Sprint ST? How much do I need to plan on spending?
Thanks for any info.
Regards,
Bruce G
Sometimes I have to pay people to do it almost the way I want it, but mostly it isn't worth the hassle so I do it myself.
