Old 09-18-2006   #1 (permalink)
All,
I had my 2001 Thunderbird Dyno'd over the weekend. I am now confused. Will you please help me decipher it?
Background: 2001 Thunderbird (Standard). Airbox has 4 holes drilled in it (As detailed in the Classic Tuning 10A document). Carbs are jetted with 40 pilots and 120 mains (as per 10A). Fuel mixture screws are 2 1/2 out from seated.
Exhaust is standard with baffles drilled out (Can't remember diameter of drill bit, but it was a hole saw, and it was as big as I could fit in.
The Dyno was done at 65-70 degrees F. Lots of moisture in the air (Fog was thick just above the ground). Tires are very new with about 300 miles on them. Bike should have been warm as I drove it 80 minutes on the highway to the station, where it sat for about 20 minutes before being run.
Also, I am preparing to install a 3 into 1 exhaust from Thunderbike New Zealand. Will this have any affect on the Air/Fuel peak?
Questions:
1. Can anyone explain what that peak in the Air/Fuel mixture is at 4250 RPM? The Dyno operator said that was normal. It is the "nature of the beast" to happen when the throttle is cracked open. ?????
2. Can anyone explain why I am not getting more horsepower and torque with my mods?
Thank You Very Much.
Rhinoe is offline   Reply With Quote
Old 09-19-2006   #2 (permalink)
Well, the tuning document probably has some caveat that it is a 'guide' not an absolute. You will have to evaluate what is happening, then respond. Jimmj900 has a few write ups, as well as view his phot album.
Here are a few links that might help:
http://www.factorypro.com/tech/carbtun.html
http://www.motocross.com/motoprof/mo...1/carb101.html (back up on this site and look around)
Yee-haaaaa!
Old 09-19-2006   #3 (permalink)
Mojoinco,
Thanks for the links. I was hoping jimmyj could help out with this too, but I guess I'll have to wait until he is settled into his new home.
Thanks,
Ryan
Old 09-19-2006   #4 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
Locking cross posting!
please see here for the thread
Mick...
Stock dyno chart webonnielad Twins Technical Talk 0 08-13-2007 03:43 PM
Tiger Dyno chart Chocorello Tiger Chat 12 02-15-2007 12:58 PM
2001 T-Bird Dyno Chart Help Rhinoe Hinckley Classic Triples 21 10-03-2006 10:01 AM
675 race pipes from NZ + dyno chart HarrispipesNZ Daytona675 Forum 1 06-19-2006 11:17 PM
stock 05 speed triple dyno chart dave_aust Speed Triple Forum 2 03-30-2006 05:19 PM
