Presuming you mean the seal at the top (large opening) of the slider (bottom half; the wheel mounts to it). And you have the two parts seperated. If the seal is stuck (old bike, probably a bit of corrosion, or just plain old bonded after such a period of loving connection they have created a 'lifestyle' relationship) you may need to heat the slider. Send your wife out for a day at the spa (or to a movie -- not sure which is cheaper) and heat it in the oven to 200~300 degrees. It should come out with some gentle prying from screwdriver (slide a piece of tubing -- old garden hose -- over the shaft to keep from dinging the tube top). Some here have used a propane torch (just heating it, not anything else), as have I. It usually only takes a minute or so. The propane adavntage is that propane tends to follow the surface around the tube versus other gases. This makes it faster, though if you have acetylene it will work fine. Just juse a rosebud (broad flame) tip.
Yee-haaaaa!
