Motorcycle.com
Old 06-05-2002   #1 (permalink)
Hi,
Where does the fuel petcock vacuum line attach on the other end? I cant seem to find a vacuum line diagram in my service manual. Thanks for your insight!
Scott
Old 06-05-2002   #2 (permalink)
On my 95 Trident with Mikuni carbs, the hose runs from the back of the petcock small outlet to the number 3 carb (right most carb while sitting on the bike). On the upper front section of the carb toward the outside is a vacuum take off point. I have a haynes manual and will look it up when I get home and scan it in for you to see what the heck I'm I'm talking about.
As far as the fuel tank end of it, you have to remove the side panel and look up under the petcock to see the backside of it. It is the smaller of the two pipes back there. Yes it does look like there is no room for a hose between there and the frame, so be careful.
Darrell
95 Trident 900
Lurch is offline   Reply With Quote
Old 06-06-2002   #3 (permalink)
Scott,
The main menu of this site has an "All news Articles" section, click on it and go to the article titled "Gas Starvation Problem". That may help with your vacuum line question.
Good luck,j98sprint
j98sprint is offline   Reply With Quote
Metal plugs in vacuum lines?!?! JBarn3 Twins Technical Talk 1 07-08-2007 05:37 PM
Engine won't start with vacuum lines plugged ChuckT120 Twins Technical Talk 5 12-24-2006 07:29 PM
Gas & Vacuum Lines - anyone replaced all of them? GatorBait Hinckley Classic Triples 6 08-22-2006 09:01 AM
Trophy 900 Fuel lines Paul900 Trophy 1 07-24-2006 10:43 AM
Help Please, Fuel/Vent/Vacuum Lines Modifications & Workshop Talk 11 07-03-2003 04:25 PM
