I've seen the solid strut done on many hardleys. All you do is get some suitable flat iron, cut to length, and drill holes. Paint it and slap 'em on. If I were going to do it, I'd get some thick flat iron (1/4inch or better), so I wouldn't have to worry about a failure. You can also make them from tubular steel where you cut to length, then take a small piece of the tube cut off and weld it to each end 90degrees angle for mounting holes. Gotta make sure the welds are good and solid. If it were me, I'd go flat iron, easier, cheaper and no special work needed (hack saw and a drill with suitable bit will do it).
Suck, Squeeze, Bang, Blow.
