AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.comBikeBandit
Old 07-16-2006   #1 (permalink)
Favorite Bike: my daytona
Other Motorcycle: kdx 200
Extra Motorcycle: honda 750 nighthawk
my battery went south , and i guess my check engine light came on,, will it clear if the low voltage is no longer present , or do i need to have it cleared . i have heard that after a few heat cyles that if the problem no longer exists the ecm will reset the code, . :???:
go funky moped go
robbo1847 is offline   Reply With Quote
Old 07-16-2006   #2 (permalink)
Favorite Bike: '01 Speed Triple
You need to run through 3 heat cycles to reset it. Start it up, run until hot, let cool X 3, and the light should go out if there is no error code present.
Speed3 is offline   Reply With Quote
Old 07-16-2006   #3 (permalink)
thanks for the info, i know on the equipment i work on , if it doesn,t reoccur the code,s go inactive , but get stored in memory until code,s are cleared.
go funky moped go
Old 07-17-2006   #4 (permalink)
code cleared light went out, thanks for the info.
go funky moped go
Old 07-17-2006   #5 (permalink)
Favorite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
The code is now stored, not cleared. They have to be cleared manually.
You can clear it with a tueboy, or the dealer gameboy.
:-g
I have enough money to last me the rest of my life, unless I buy something.
chefjpd is offline   Reply With Quote
Check engine light...on again off again monroe731 Sprint Forum 7 04-11-2008 03:53 PM
Check Engine Light HTH13 Tiger Workshop 5 03-08-2008 01:01 PM
check engine light on? speedytriple Speed Triple Forum 1 06-25-2007 06:35 AM
check engine light PROMOD1385 Speed Triple Forum 1 03-18-2007 08:10 PM
