Old 06-18-2004   #1 (permalink)
I have a two brothers slip on can installed on my sprint rs and I use the Tuneboy download to change my fuel mapping. The gain in mid range acceleration is fantastic. But on deceleration I notice a lot of popping noises. I used to think that this was due to running rich, due to unburnt gas. But a mechanic friend of mine says that maybe it is running to lean and that I should change to another fuel mapping that would cause the bike to use more gas and run richer. Does anyone out there have any ideas?
Old 06-18-2004   #2 (permalink)
Popping on decel is indicative of a lean closed-throttle (idle) condition. You can try to reduce it by richening the idle part of the map, but you won't eliminate it (it's in the nature of free flowing pipes).
dietDrThunder is offline   Reply With Quote
Old 06-18-2004   #3 (permalink)
Favorite Bike: HD XL1200C
DITTO - running too lean. Need to get more gas flow.
97TB is offline   Reply With Quote
Old 06-18-2004   #4 (permalink)
Favorite Bike: 2002 Sprint ST
Since you have the TuneBoy I'd assume you have the TuneEdit, cable and lock. Get some dyno time and sort it yourself instead of trying canned tunes. This is what it's really for.
Don
Popping on Deceleration tspapa Twins Technical Talk 8 11-01-2007 08:51 PM
Popping on deceleration smartin108 Twins Talk 8 09-03-2007 03:21 PM
Popping on deceleration Loxpump Twins Technical Talk 2 10-08-2006 07:07 PM
Popping on deceleration IndyRocket3 The Rocket Science Forum 4 09-04-2005 10:41 PM
popping on deceleration dazco Twins Talk 4 07-02-2005 12:15 PM
