I'm in the process of adjusting my valve clearances (two exhaust valves are slightly under spec at 12,000 miles) and the cam chain has me stopped.
I've removed the chain tensioner and all the caps holding the cam shafts. Crankshaft is set at TDC. The manual says with the tensioner removed, there should be enough chain slack to let me remove the cam shaft (without removing the sprocket from the shaft). But there's not quite enough slack in the chain. Can anyone help?
Bern
