» Links |
| Modifications & Workshop Talk Maintenance, Troubleshooting or Creating Fabulous Custom Machines... |
06-12-2006
Formula Extreme Favorite Bike: 2003 Sprint ST
Posts: 602 Other Motorcycle: 1970 Bonneville Extra Motorcycle: 1972 Norton Commando
Hey all,
I have been looking for a couple of 10-1.25X150mm stainless allen socket head cap screws. I cannot find them anywhere here in the U.S. Anybody know a source that would ship to the U.S. and wouldn't charge a fortune for two bolts? Please PM me too if you know a source.
Thanks
World SuperBike Favorite Bike: 98 Thunderbird
Posts: 2,014 Other Motorcycle: 91 Zephyr 750
I checked my usual supplier, they only go up to 100mm.
Why not use some threaded stud and cut to size?
06-12-2006
Site Supporter Moto Grand Prix Favorite Bike: Well, Duh!
Posts: 3,063 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
the problem in the US is finding 10x1.25 its not the standard for an M10 bolt here, as it is in Japan and (I believe) the UK. It is more commonly known as a metric fine here. I too tried to source some of these and drew a blank - all I could get was regualr hex head cap screws in steel with a plated finish.
Mick...
06-12-2006
The fine pitch seems to be only common on vehicles. Most other applications use a 1.5 pitch.
06-12-2006
Its just the Japanese standard then. I believe Triumph use this so that they are compatible wiht the parts sourced from Japan / the far east
Mick...
06-13-2006
They will go on my LSL frame sliders (German I think). The ones they (LSL) supplied are too short but they will not get me some that are longer. The ones supplied only have about 7-8 mm of the threads engaged into the mounting block while the block is at least 25 mm thick. A guy on the Sprint forum had his break off during a slow low side. I checked mine and it appears they are too short.
06-13-2006
If they is rumor of these breaking I would use plated steel instead of stainless it is much stronger.
Mick...
06-13-2006
Mick,
The problem was the bolt stripping out the mounting pad. It doesn't look right the way it is. Why have a mounting pad that is 25 mm thick but only 7-8 mm of bolt penetration? It makes no sense. I also thought about re-tapping the mounting pad with a 10-1.5 tap??
06-13-2006
I think you are probably right on the length issue John. I was musing on the fact that a plated 150mm one may be better still.
Unfortuantely the online catalogs I use don't list 10x1.25 socket head in plated, just plain steel.
I would not attempt to re-tap without changing size or having an insert fitted.
[ This message was edited by: MickMaguire on 2006-06-13 09:47 ]
Mick...
06-13-2006
These guys might be worth a call:
click here
Their online catalog shows 10-1.25x150 but does not say about the material.
Mick...
