Gentlemen: HELP!!! I would like to ride again in my lifetime!
Problem:Starts with choke on and half throttle but stalls after choke is released.After a while will keep running(with choke off) if throttle is at least halfway but stalls when released.Very noticible loss of power when finally moving in first gear but stalls when throttle is released.I have a new battery,new plugs and points are correctly set.I disassembled the carbs to find a hard powdery beige substance caked on in both carb bowls(more in the right carb than the left).Cleaned both carbs,main jet and all fuel lines.Floats look good.Both carbs thoroughly flushed. Is there anything I have overlooked?I am not a great mechanic so any advice(very thoroughly and SIMPLY PUT) would be greatly appreciated(Adjustments to cables,screws etc.) Bike has approximately 16K miles on it.I have had the bike since 1972 and this is the first time I couldn't get her going.Thank you in advance for your kind help.
John
