Old 06-09-2006   #1 (permalink)
Please take a look at this link real quick....
Relay with Jumper
In those intructions it says you need a "6 post distribution block" and jumper. The distribution block is the one thing they don't show a picture of and I having a heck of a time finding one. I can't find any pics online and when I went to one of my local radio shacks they gave me a distribution bridge instead. When I was buying everything else at O'Reilly's auto parts store they sent me to radio shack.
Can anyone show me what the distribution block looks like, maybe where to get it, and if not... something to get in place of it??? I went through those instructions last night and wired everything up the way it says, so all i need to do is stick the distribution block in to the system and I'm all set.
Thanks!!!
-dennis
2004 Triumph Thruxton
d2mini is offline   Reply With Quote
Old 06-09-2006   #2 (permalink)
A distirubution block is also commonly called a terminal strip. Radio Shack sells them, I think even Home Depot sells them, call a local electrical or communications supply house (Graybar, etc). You will want the jumpers that connect all of the one side together (in the parts picture it is the long strip of forked metal), and the jumpers that go to the other side of the terminal strip (connects across two rows to connect just two termianls together).
Alternatively, just get the forked strip (or a terminal strip with all of the junctions connected) and a single row terminal strip. You could even just use a stainless (for corrosion) screw and bolt all of them together, but that looks ugly.
Most terminal strips use #10 screws, so you will want #10 rings for yuor wiring (forks work ok, but no tolerance for working themselves out, unless you use the kind that have bent up ends).
Yee-haaaaa!
Old 06-09-2006   #3 (permalink)
You'd probably have best luck with a distribution block at a decent RV store. I haven't seen them with a relay built in, but I haven't looked for them either
You can find REALLY fancy - read: pricey - blocks at automotive sound dealers.
I'd probably opt for a block with individual fuses; it'll make your power distribution a little easier and a lot safer. I haven't dealt with these people but something like this would probably meet your needs:
fused distro block
You can always add an external relay to power the block.
Please keep in mind that aftermarket mobile electrics are a source of a LOT of problems - make all your connections stronger and better protected than you'd think, and it'll probably be just about right.
Be nice to America or we'll bring democracy to YOUR country...
vinnyf is offline   Reply With Quote
Old 06-11-2006   #4 (permalink)
That setup is fine with one exception. The way it is wired, all your accessories will be drawing power over one 18 gauge wire. On my bike, the main power wire is 14 gauge. This will carry the load much better than a smaller wire. It also matches the wiring on the 20 amp rated fuseholder, which protects the whole installation.
Hugh
HughDeMann
71 T100C 64 T120 98 Sprint Executive 71 TR25W project
74 Commando 49 Big Four w/chair
several others
Hughdemann is offline   Reply With Quote
Noise diagnosis for the gurus tbh9088 Hinckley Classic Triples 3 01-13-2008 09:31 AM
Question for luggage gurus HGaither Tiger Chat 3 02-04-2007 08:11 PM
OK You Gurus of these things... TRI-AL Classic, Vintage & Veteran 2 01-15-2007 02:13 AM
For the electrical gurus in the house... Catamount Speed Triple Forum 18 10-19-2006 05:35 AM
Any powder coating gurus - or anyone else? InfX708 Modifications & Workshop Talk 8 09-08-2004 11:18 PM
