> Could it be that it jumped time or valves not opening?
Yes.
But "could" doesn't mean a lot in the long run. When you say you removed the plugs and "the compression was gone," that's a bit ambiguous. What exactly happened after you put the plugs back in...or did you? Of all the things you removed, did you happen to open the valve inspection ports and see if they were, in fact, being opened?
John
