Old 06-04-2006   #1 (permalink)
I am getting the oil pressure warning light coming on once the bike has warmed up. higher rpm seems to trigger it, the light does not come on fully but is much dimmer than at startup (ignition on, bike not running). Oil level is fine, bike has 4700 miles on it and break-in oil was changed out at 500 for Mobil 1 4T, it just started happening Friday night, no problems before that. Only thing different is I have not rode much over past 2 weeks due to a rear flat and working a lot of hours.
I am guessing that any fix would be under warranty but am loathe to have it sitting in the shop right now, riding weather is too good, so would like to troubleshoot myself.
Anyone had the same or similar problem?
Any input much appreciated.
yn reis ta neuchreeaghnoil
HorseWhisperer is offline   Reply With Quote
Old 06-05-2006   #2 (permalink)
Hi ,
I had this problem on my old bike a Yamaha thundercat , finally traced it to a loose wire going to the oil sensor .
Don't let the B******s grind you down !
Dingle is offline   Reply With Quote
Old 06-05-2006   #3 (permalink)
I am inclined to think you are right, oil level is good. I had the console nd sprocket for chain clean and lube and a coat of wax on the tank.
Next question ....... where's the oil sensor, I see it on the wiring diagram, but where is it on the bike? :???:
Glowing Oil Warning Light - TBS robnobrakes Hinckley Classic Triples 1 12-29-2007 09:06 AM
Oil warning light stays on trophy_cup Trophy 4 10-06-2006 08:11 PM
low oil presure readings ? rckrzy1 Speed Triple Forum 1 09-11-2006 09:06 AM
S3 -05, Oil pressure warning light is on Xibalban Speed Triple Forum 2 05-28-2005 08:41 PM
flashing oil pressure warning light Sprint Forum 2 09-12-2004 08:59 AM
