I need to replace the very worn chain slider on my 95 Daytona (now that I have managed to get the countershaft nut loose). It looks like I need to remove the rear shock and spring in order to allow the swingarm to drop low enough to get at the bolt on the side of the swingarm. The shop manual says nothing about replacing the chain slider so it's no help. I tried lifting the bike to completely unweight the back end but the swing arm does not drop low enough to access the bolt. However, the description for removing the rear shock/spring unit indicates that once the mounting bolts are removed th eswing arm is lowered to make room for the removal of the shock/spring. I was hoping somebody here has experience with this just to confirm before I spend a couple of hours on the project. Thanks.
