BikeBandit
Old 05-30-2006   #1 (permalink)
trydave
1969 bonny t120r, bike totally rewired with negative ground. I have designed a completely indestructible ignition system and the one final thing I would like to do is eliminate the battery. I am thinking the system would have to provide at least 5 amps at idle because the head and tail lights must be on. Anyone got any ideas? thanx for reply!
[ This message was edited by: trydave on 2006-05-30 02:54 ]
Old 05-31-2006   #2 (permalink)
Favorite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
perhaps a magneto to go along with the kickstarter?
maybe sourced from HD sportsters of the 60's variety?
Just throwing out ideas
I have enough money to last me the rest of my life, unless I buy something.
chefjpd is offline   Reply With Quote
Old 06-01-2006   #3 (permalink)
Favorite Bike: 98 Thunderbird
A magneto would be cool, but they seem to be rare and pricey.
They used to use large size capacitiors for battery elimination. I forget what they were called.. post this in the vintage & veteran forum and you should get some more precise information.
PS a three phase alternator would be a good idea too.
[ This message was edited by: Slinky on 2006-06-01 02:03 ]
Old 06-02-2006   #4 (permalink)
chefjpd's Avatar
You can look to the custom audio crowd for HUGE caps. they use them to store charges for massive bass hits.
Can you run a 3 phase alternator without a battery? is there a similar unit that acts as a generator??
Are we helping?
Old 06-02-2006   #5 (permalink)
trydave
Sorry I got back so late but yea! Great help! I like the 3 phase alt idea! Yes it would run. I could split the alt output! Two phases for the engine and the other phase for the lights. Thanx for the cap idea also! Ive been looking for a cap that large but didnt know where to find one. Thanx for the help!
[ This message was edited by: trydave on 2006-06-02 19:13 ]
Old 06-26-2006   #6 (permalink)
chefjpd's Avatar
old thread, but I just saw this:
Ebay Capacitor
:-D
Old 01-29-2008   #7 (permalink)
Cool
There is a magneto Co,that I am not allowed to name,that sells the capaciter for under $50.00.
magman is offline   Reply With Quote
Old 01-29-2008   #8 (permalink)
Favorite Bike: 95 Thunderbird; 96 Sprint
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Hi,
Sparx produce a number of enhanced Triumph/BSA Lucas bits for our classics.
http://www.sparxelectrical.com/acata...Capacitor.html
It looks like the US Ebay item is the same, and it perhaps would be worth contacting Sparx to find out a local stockist to you?
Ah.......this is a very old post.
Geoff
GeoffE is offline   Reply With Quote
Old 01-29-2008   #9 (permalink)
Diego's Avatar
Completely bogus idea! Sorry. You'll risk ruining the alternator for no benefit at all.
Nothing wrong with using either a conventional single or three phase alternator (with the correct rectifier and regulator) just as-is. The trick is choosing an electrolytic capacitor of sufficient rating to keep the power relatively ripple-free at idle. Also be aware that the voltage may dip quite a bit at idle, which won't be a huge problem for the lights, but you may find your "indestructible" custom ignition struggling to keep going... or even to fire when merely kick-starting... unless you've designed it to be able to work with lower voltages.
John
No Ignition lovecuba Hinckley Classic Triples 2 10-04-2007 03:57 PM
07...no ignition skuuter Speed Triple Forum 5 07-02-2007 05:12 AM
BC Ignition JTKMX Twins Technical Talk 14 11-07-2006 06:16 PM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 12:50 PM
No Ignition RHD47 Twins Talk 12 05-09-2006 04:52 PM
