Old 05-24-2006   #1 (permalink)
hashman
Posted this issue under Cafe section.
My 2005 thrux, cranks over, all plugs OK and power to the coils.
No spark = no go. Was intermittant, now permenant.
As I have'nt the Hayne manual yet, can any one give me specs, ie resistances of coils, across crank sensor etc and how you check these things.
Although only 4 months old, the triumph dealer is a long haul away so I want to try and get to the problem first.
Cheers.
Old 05-25-2006   #2 (permalink)
13
Favorite Bike: BRITTEN
Other Motorcycle: 955i
New bike! I vote low battery!
Coil resistance on my Triple spec'd to 0.7-0.9 ohms, read across two pin terminals. Your Thrux not sure. I'd check battery, maybe charged enough to turn starter, but not enough to fire ignition.
I was working with a BMW (auto) mech from Germany. BMW gave him a new RT to tour around here on. He could not even start it (stand down and in gear)! He was stuck for an hour like that on the road!!! Faulty kickstand/ neutral safety switch?
Hope this helps!
SPEED SAVESİ
13 is offline   Reply With Quote
Old 05-30-2006   #3 (permalink)
trydave
put your meter on dc volts across the coil input terminals and crank the bike over. The voltage should rise and fall or pulse up and down. If it doesnt the firing sensor is bad. If it does the coil is bad. By the way an anolog meter will be easier to see the pulse...
[ This message was edited by: trydave on 2006-05-30 11:10 ]
Old 05-30-2006   #4 (permalink)
Favorite Bike: '98 Thunderbird Sport - Buford
denny's Avatar
Other Motorcycle: '96 Thunderbird - Bessie
Extra Motorcycle: Anything that runs
My TBS had this problem recently. I found one of the two wires that run from the ignition sensor into the wiring harness was broken at the connector.
Cheers,Denny
denny is online now   Reply With Quote
ignition problems bkjones Triumph SuperSports 10 08-01-2007 07:27 AM
Ignition problems Ozz Triumph SuperSports 6 02-16-2007 07:47 PM
Ignition problems dean68uk Daytona Deliberations 2 12-13-2005 10:05 AM
Ignition problems Classic, Vintage & Veteran 13 05-25-2005 02:19 PM
Ignition problems scarling Daytona Deliberations 11 10-10-2003 12:33 PM
