Before you dive into the speedo drive, check the chain tension - if it's adjusted too tight, the transmission whines.
Recommended tension is 35 - 40mm with the bike on the ground, not on a paddock stand etc.....
Ignore it, and you run the risk of causing premature wear on the output shaft bearings, the sprockets and chain.
Last time my bike was serviced by a dealer, the chain was adjusted too tight.....
[ This message was edited by: Bob955i on 2006-05-12 14:18 ]
