Cheers, BadDog,
You really need to check a couple of things - I'd start buy pulling a plug wire, stick a screwdriver into the plug cap, and put the screwdriver shaft a couple of mm from some metal part of the bike. Hit the starter and check to see if you're getting a nice arc from the screwdriver blade to the metal; if so, your ignition is probably ok. Next step, IMO, is to pull a plug and have a look - if you've cranked a bit, it should be wet with fuel. If not, something is stopping the fuel from flowing. Has the bike been sitting - unused - for some time, like the winter? If so, your thought about draining the carbs is well founded, but may be a bit late, as they may already be clogged. Let us know how your ignition check goes, and we'll take it from there.
vinny
Be nice to America or we'll bring democracy to YOUR country...
