Old 05-08-2006   #1 (permalink)
Can the position of the Rear Brake lever be altered?
I find it is too high and would prefer it to be lower so I don't have to angle my foot up so high to reach it.
cheers
Anne is offline   Reply With Quote
Old 05-08-2006   #2 (permalink)
Favorite Bike: 01 Sprint ST Turbo
tommyturbo2's Avatar
Other Motorcycle: 01 Bonnie Golden Jubilee
Extra Motorcycle: Suzuki DR400E dirt bike
Ann: The rear brake can be lowered by adjusting the length of the shaft that goes into the master cylinder. You'll see there's a locknut and a clevis pin to pull in order to rotate the threaded shaft to lower the pedal position. good Luck, tommyturbo2
TTG..Three Triumph Garage
tommyturbo2 is offline   Reply With Quote
Old 05-09-2006   #3 (permalink)
Cheers Tommy I'll have a look at it
Steel braided brake hose for rear brake midliferider Hinckley Classic Triples 4 05-20-2007 04:29 PM
Hot rear rear brake.????? rs_tt Modifications & Workshop Talk 5 04-11-2007 11:55 PM
Correct position for brake lever on rear conical brake johnquinnell Classic, Vintage & Veteran 11 03-09-2007 03:42 PM
Bonneville front/rear brake lever adjustments??? mecscc Twins Talk 9 04-12-2006 07:42 AM
Bonneville T140 Rear Brake Problems crazypierre Modifications & Workshop Talk 7 05-04-2005 06:21 PM
