Motorcycle.com
Old 05-20-2004   #1 (permalink)
Favorite Bike: 1999 Adventurer
Other Motorcycle: 2008 BMW K1200LT
Extra Motorcycle: 2004 Bonneville Black
On my 1999 Adventurer there is a definite buzz or engine sensation that I can feel at 3000 RPM. It doesn't seem real alarming, but everytime I hit the 3000 RPMs I feel it... in any gear. Is it maybe an inherent resonance in these bikes?
This is my first Triumph and only put 400 miles on it since I got it, so still getting familar with it. (6800 miles on the odometer)
thanks again guys!
Joe
"If you're born to be shot, you'll never drown"
jdumas54 is offline   Reply With Quote
Old 05-20-2004   #2 (permalink)
might be a piece of plastic ? vibrating
I speed, Klugman
Klugman is offline   Reply With Quote
Old 05-20-2004   #3 (permalink)
Favorite Bike: 98 Thunderbird
It's normal, they all do that to some extent. On my own bike I only notice it if I am accelerating thru 3000 revs. The harder I accelerate, the more pronounced the buzz. At a steady speed there is no buzz at all.
Forget about it, after a while you will not even notice it.
Old 05-21-2004   #4 (permalink)
It is normal behavior on the Triples. It smooths out and all but disapears with more mileage. We describe it as a harmonic vibration. I'll bet you notice no power loss? How many miles do you have?
- Jerry V. - Northern NJ
Jcatbert is offline   Reply With Quote
Old 05-21-2004   #5 (permalink)
jimmyj900's Avatar
The 3K buzz is normal and gel grips on the handlebars are quite helpful for reducing the feel of it.
Jim
CAUTION: This post may have been altered and critical safety information deleted without the permission or knowledge of the author.
Old 05-21-2004   #6 (permalink)
thanks again guys for the replies. I kind of thought it might be some kind of harmonic resonance at that RPM, but wanted to make sure. There isn't any power loss, or anything, just this brief, fleeting minor annoyance- I can easily overlook. I just avoid cruising at 3000 RPM and all is wonderful!
(6,800 miles)
Rain and clouds forecasted all week!!! Daayum!!!
Old 05-21-2004   #7 (permalink)
these engines have a counterbalancer that kicks in and out at certain revs (design of the beast) and 3000-3500 is when it senses vibration and cancels it from there on if you throttle back in forth between 3000-3500 you can regulate it and know its doing its job then when you pass 3500rpm it is smooth up untill redline or before depending on how fast and furious youre going
[ This message was edited by: shedds on 2004-05-21 15:05 ]
shedds is offline   Reply With Quote
Old 05-22-2004   #8 (permalink)
watty
Hi all, the vibration you describe should come in around 2800 revs and minimise around 3800 revs and happens on every triple I've ridden. It's caused by the triple harmonics causing the clutch basket to vibrate; it can't be cured but can be changed or minimized by taking the basket off and shimming the free play out using Triumph shims sold for that purpose. I've done it a few times, it's not difficult if you know your way around a clutch but free play naturaly comes back in time. Hope this helps, cheers, Watty ( Washington, England)
Old 05-23-2004   #9 (permalink)
That's interesting Watty, that is the first plausible theory I have heard for the source of the "harmonic"
Mine is so minor I won't be rushing to strip out the clutch, but it's worth bearing in mind.
I sometimes wonder what it would be like to remove the balancer from these engines. They must sap a fair bit of power, and a 120 degree triple should be pretty smooth anyway?
Old 05-23-2004   #10 (permalink)
Favorite Bike: '04 Thunderbird
Other Motorcycle: 1998 Honda CBR1100XX
A 120 triple should indeed be smooth - but it needs the balancer shaft to sort out the end-to-end vibrations which exist.
See: http://autozine.kyul.net/technical_s...1.htm#Inline-3
I'm NOT an engineer and am happy to be be advised to the contrary, but this article makes sense to me.
NB: The Triumph motors have a 123 firing order rather than the 132 illustrated, but I don't think this makes any difference.
Jodel is offline   Reply With Quote
My 07' Thruxton 900 idles to high at 3000 rpm DJ KOOLNESS Club Cafe 7 12-06-2007 03:17 PM
Infraction-induced auto-ban? R100Pilot Speed Triple Forum 9 10-12-2007 03:39 PM
I got the buzz! MikeRokkit The Rocket Science Forum 13 03-08-2006 04:37 PM
Strange S3 induced illness... Geof3 Speed Triple Forum 2 09-03-2005 06:18 AM
Engine stops below 3000 RPM T3 Sport / Touring Forum 13 10-17-2004 12:03 AM
