I checkd the "search" for this and nothin came back relative to this.
So what do you guys think the reason is? Is there a adjustment somewhere? I am guessing the detent/switch isn't hitting correctly. Sometimes the light comes on when I go into neutral and sometimes it doesn't. Maybe a bad ground/connection at the bulb... ?Anyone else have this problem?
"If you're born to be shot, you'll never drown"
I had exactly the same problem on my "other" bike a few weeks ago, it turned out to be a dirty & loose connection where the cable connects to the neutral switch.
__________________ "You can't fly with the eagles if you keep scratching with the turkeys."
I find that the neutral light fails to come on when my bike is hot.When I let the clutch out the engine cuts and only starts when I pull the clutch in.When its cool it behaves normally.
It`s not a major worry but I would like to fix it.Is yours doing the same?
