Motorcycle.com
Old 04-14-2003   #1 (permalink)
My rear brake caliper is dragging more than the slight drag it should have. The pads are good (although at the end of their usable lives) and the fluid has been changed according to schedule.
I've ordered the rebuild kit of pistons and seals and will rebuild it. If anyone has done this is there anything I should watch for?
It's been dragging for a while, enough to knock 4 to 5 mpg's off but not quite enough to turn the rotor cherry red.
j98sprint
j98sprint is offline   Reply With Quote
Old 04-14-2003   #2 (permalink)
Favorite Bike: Well, Duh!
MickMaguire's Avatar
My 2 cents: I would definately check the rear rotor carefully for glazing and runout if haven't already.
Mick...
Old 05-31-2003   #3 (permalink)
Rear calipers are always a pain. Corrosion makes the pistons stick slightly and not return properly.
Only remedy is to strip and clean up corrosion. Usually needs doing after winter in UK after salt has done its worst....
illusionist
illusionist is offline   Reply With Quote
Old 05-31-2003   #4 (permalink)
illusionist
thruxton rear brake caliper Treehugger Club Cafe 12 02-13-2008 02:47 AM
Rear brake caliper Scrambler bung1 Modifications & Workshop Talk 4 09-04-2007 04:38 PM
Noisy rear brake caliper mounting bracket spm0912 Speed Triple Forum 0 07-17-2007 02:00 PM
HELP!!! REAR BRAKE CALIPER FOR '94 900- INFO!!! johnnycactus Daytona Deliberations 2 10-13-2005 11:54 PM
Rear brake caliper TrumpetST Sprint Forum 1 08-24-2005 12:36 PM
