Hope someone can help. After installing the PCIII and having a custom map done w/equip removed, found there is no 02 sensor bypass available. Had to leave the 02 sensor unplugged for the map to stick.
Problem - the "Check Engine" light stays on even after having the dealer reset the ECU. Does anyone know of a fix or a bypass available? Possibly a wire loop?
Any help will be appreciated.
Thanks,
Cigarman
