Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
Old 05-15-2004   #1 (permalink)
Hope someone can help. After installing the PCIII and having a custom map done w/equip removed, found there is no 02 sensor bypass available. Had to leave the 02 sensor unplugged for the map to stick.
Problem - the "Check Engine" light stays on even after having the dealer reset the ECU. Does anyone know of a fix or a bypass available? Possibly a wire loop?
Any help will be appreciated.
Thanks,
Cigarman
Old 05-16-2004   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
How many heat cycles have you been through? I was having brain fade up in the 600s forum. If you still have a problem light after three heat cycles, Triumph has set up the D6 ECU completely differently from any other bike they make.
Will
SponsorHouse profile
Old 05-16-2004   #3 (permalink)
Hi Will,
Won't help. The dealer tried to reset the ECU but no help there. As long as the 02 lambda sensor is unplugged the light is on. Need some sort of loop or bypass.
For example, Dynojet has an 02 sensor bypass which just plugs in. No FI light.
Check engine light...on again off again monroe731 Sprint Forum 7 04-11-2008 03:53 PM
pc III, no 02 sensor eliminator, check engine light. jdub3 Speed Triple Forum 6 07-31-2007 08:56 PM
fuel level sensor + check engine light? argh Speed Triple Forum 0 06-14-2006 11:17 AM
Check engine light Speed Triple Forum 1 07-02-2004 01:19 PM
PCIII and O2 sensor problem Triumph SuperSports 2 05-16-2004 08:14 PM
