Need to find out if anyone knows of anybody that makes a good quality 90 degree quick release fitting for the hoses that come off the fuel pump on a 00 Speed triple - have had a couple of the factory plastic ones split and when the ignition is turned on fuel sprayed
(have to admit not sure how the other end of the quick release fitting is attached to the fuel pump so not sure if will need to replace the whole line setup)
