Motorcycle.com
Old 05-23-2002   #1 (permalink)
Anyone out there know how to reset the engine management system warning light? (other than take it to the dealer..) Iv'e tried the old "remove the battery trick" which didn't work :???: Any insight would much be appreciated!!
Old 05-23-2002   #2 (permalink)
Hi Alan, Have you run out of gas or anything to set it off lately? If something like this has happened it will reset itself after 4 or 5 heat cycles, if the nothing has happened then you probably need to have the dealer check for codes in the comp. for problems.
Ran out of gas the first day I had my TT600, light worried me to death until the dealer told me that it would reset by itself for that fault. Tried like you to unhook the battery but the comp. has a battery inside to save trouble codes or something.
Hope this helps...JD
Old 05-24-2002   #3 (permalink)
JD:
That may be the problem. I did not run out of gas yesterday; however, I did come pretty close to it. I will see if it resets itself in the next 4-5 times I ride it. I'm due for my 12,000 mile check up shortly anyway. Thanks for the tip!! :-D
Engine management light carr955 Daytona Deliberations 6 07-31-2007 04:39 PM
engine management light!!!! riley290 Triumph SuperSports 2 05-31-2007 10:55 PM
Engine Management light on EriePark Sprint Forum 3 08-09-2006 02:35 PM
engine management light on. banni955 Modifications & Workshop Talk 2 08-28-2005 07:58 PM
Engine management light niteowl955i Sprint Forum 2 08-10-2004 03:01 AM
