Hi Alan, Have you run out of gas or anything to set it off lately? If something like this has happened it will reset itself after 4 or 5 heat cycles, if the nothing has happened then you probably need to have the dealer check for codes in the comp. for problems.
Ran out of gas the first day I had my TT600, light worried me to death until the dealer told me that it would reset by itself for that fault. Tried like you to unhook the battery but the comp. has a battery inside to save trouble codes or something.
Hope this helps...JD
