Old 02-10-2006   #1 (permalink)
aal52
I think I may have just posted this in the wrong section, so I'll repeat it here:
"Hello all. I'm new to Triumph and this site. I just got a hardtail with a 67 650 in it. I have questions. It's been modified somewhat. First, the primary is open; that is it's dry. I'm told this is a somewhat common thing to do. My question is, how do you lubricate it? Thanks."
Thanks.
Old 02-10-2006   #2 (permalink)
If it is an open chain primary, then clean and lube like the drive chain. If it is a belt, then just hose off dust and debris with water. Another thing, dry clutches often aren't very fond of water, so try not to soak the clutch.
[ This message was edited by: Joe-Dirt on 2006-02-10 13:47 ]
Joe-Dirt is offline   Reply With Quote
Primary Oil dorkingbonny Classic, Vintage & Veteran 25 04-08-2008 04:59 PM
need a primary cover preunit13 Classic, Vintage & Veteran 13 07-04-2007 05:31 PM
primary oil dirtyharry Classic, Vintage & Veteran 6 06-13-2007 02:30 PM
primary nut gm16sw Twins Technical Talk 4 07-05-2006 06:46 AM
open primary aal52 Twins Talk 1 02-10-2006 05:56 AM
