for the hole thats left in the airbox from the big hose on the AI, i used a rubber cork sealed in with silicone. I cut the plug very short otherwise it bottoms out and doesn't hold well because it can't go in far enough to sqeeze tightly against the edges of the hole. rubber corks can be found in various sizes at many hardware stores. Tried one of those plastic hole covers but it wouldn't hold because the edges of the hole taper down so theres no way for the little clips on the plug to grab.
