Motorcycle.com
Old 01-19-2006   #11 (permalink)
Tequila1
and buy good tools!! cheap tools thread bolts!!
Old 01-22-2006   #12 (permalink)
Favorite Bike: Daytona Super III
Hinckley's Avatar
Other Motorcycle: Suzuki GT750
Extra Motorcycle: CB900F FOR SALE!
Hey BadDog, did you get this fixed?
If not, I have an extra master I would be willing to part with. Send me a PM if you are interested.
UFOB #56
Hinckley is offline   Reply With Quote
Old 01-26-2006   #13 (permalink)
Here-here on the tools: MOST phillips (cross head) drivers are relatively soft. It takes effort to find hardened tipped units. Sears Craftsman 'pro' line are. Xcellite makes them, as do Wiha (German, but web purchases are easy). I have found that the easiest way to get them is to go buy the 1/4' bit inserts for power driving at the hardware store (if you have room for them). The best of these are the Vermont American, as they have 'acr' (anti cam reduction) reduction ribs that run perpundicular to the flutes (little ribs that help keep the tool from sliding out as you turn the driver).
Another trick is to buy a hammer operated impact wrench (they are fairly cheap). By pushing down on them hard enough you force the spring to compress a bit. Do this while turning and it often is all you need. Just use the good bits (they come with a few hardened ones). it also seems to help because it gives you a large area to grip with.
Using the impact wrench (often with a hammer) and anti-seize, (the first time you take a screw out), you will save yourself a world of hurt. One caveat: using anti-seize changes the torque you should be using. I found a small refernce volume listing thes (and a million other things -- great reference, but can't remember the name) conversions. The product used may have this data available on its web site.
Yee-haaaaa!
master cylinder SpeedBob Speed Triple Forum 5 08-15-2007 09:57 AM
Front brake screw broken OgmernIWulfsail Twins Technical Talk 11 04-24-2007 12:21 PM
New Master Cylinder on 2007 S3? Boss Speed Triple Forum 4 10-02-2006 09:51 PM
Nissan Master Cylinder rodneybrown Sprint Forum 2 09-21-2006 07:32 AM
Damaged Screw Head in Master Cylinder BadDog Speed Triple Forum 0 01-02-2006 10:27 AM
